Setting up a hydros doser
Rockdiver
chicago
Hello all just got this doser and I understand how to put it into the collective, by reading but first I have a few questions since this is my first doser.
Does This plug in to the orange port on my Launch ? the cable is not color coded.
How is this put together as in can the head be in any direction up down left or right?
Can I put this slightly far from the tank ?
Does it matter what side/ tube I have coming from the container and what side to the tank ?
A picture of some set ups would be cool.
Thanks
I used one of these for about 2 years as my ATO pump. It was in my garage where my DI reservoir is located. The tank is 35ft from the garage. The tubing runs through my attic between the pump and the tank. I now use a Sole for this but that was just because I was trying it out and the ATO was a good way to put it to use. The pump still runs and I may put it back in use as ATO or may use it as the drain pump on my iV. Yes the pump is powered off a drive port. The launch has 4 of those ports. You can set it up as a dosing pump and setup a dosing schedule or use it in outputs such as ATO or generic outputs if you want. I had the tubing pointed down in my application but I think it can be in either of 4 positions.
On the pump does it matter how the head is positioned ?
Also the intake line on the left or right as your looking at the front and the head is positioned down see pic seems on the right the line has writting on it or it dont matter ?
Thanks again !
If I remember correctly I think it is on the right side with the head in that position.
It's odd they don't put a in / out marking IDK
I will see when I hook it up.
Also got a WE v2 so I'm setting that up right now
Thanks Danny
