Check out Depends On below your skimmer output. Make it depend on your doser with an off if on dependency mode. If you want the skimmer to be off for a period of time after dosing then create a combiner output which references the doser as an input, no output device, advanced settings toggled on and a minimum on time equal to your desired skimmer shutoff duration. Then make your skimmer depend on the new combiner in the same manner. If you are dosing multiple things then you can just change the input count on the combiner and select the additional dosers. Use an OR combiner mode and skimmer will be off if any of them dose.
