This is exactly how mine is, but it should say alert when wet.
So are you saying if the sensor is wet when not selected it will alert me?When you set the alert level…. In this case I made it yellow. The “ Alert when Dry” will pop up. The toggle to the right of it allows you to switch it .
YesSo are you saying if the sensor is wet when not selected it will alert me?
Gotcha. Seems like an odd way of setting it. Almost should be 2 options for the alert. 1 for dry and 1 for wet.
