the right plugs
Carsten
USA
Hi,
I love the pinout sheet as it helps explain all the pins. Can we work together to supplement it with the right plugs/sockets for each cable type?
I would love a reference to where you buy them too.
I have been trying to buy them but I ended up with versions that are too big. What kind of plugs are used here?
Hi,
If you are referring to the connectors for the input and output ports they are GX12 connectors. You will need to get the ones with the proper number of pins depending on which port you are going to use them with.
That is what i missing, thank you! GX12 connectors - it is a whole family of connectors. I thought each of them had a different number ...
