Hello I have 2 tunze 6105 I am trying to add to my wave engine I have the 0-10 cable as well as the adapter and I hooked up correctly when I add the output but and it shows the percentage the power to the pump there is no flow any suggestions
I have them powered up using there power supply I put 0-6.5 as recommended but it’s not working the out put shows that they are running show the percentage of the flow but there is no flow I have them on my pump schedule and still nothing thanks
I am literally having the exact same issue with two 6055s. I’m leaning more towards the wiring harness either the four port “squid” adapter or the individual Tunze to the headphone jack cables. Very frustrating to say the least since they work perfectly on their own controller just not with the Hydros 0 to 10 V DC output.I have them powered up using there power supply I put 0-6.5 as recommended but it’s not working the out put shows that they are running show the percentage of the flow but there is no flow I have them on my pump schedule and still nothing thanks
Have you had any luck? I see this was from about a month ago.
Thanks for the response. Both Tunze controllers are set to “remote” and I get 0 propeller motion in all settings on WEV2. I tried my multimeter today and I think it’s the Tunze end to 2.5mm jack. I believe the cables to be wired incorrectly from the factory since I get voltage directly from the WE pin output with my meter.Remote control feature need to be enabled and calibration dine calibration on Tunze side. Do you know how to and IF remote control is enabled? Then calibration--which may be optional--sets the low and high flow percentages. High doesn't really matter but low is typically between 15% and 30% as most brands tend to stall if set any lower. Think I recall seeing a calibration video on here a while back that you can search if you need tutorial.
