FYI, you can adapt the Tunze ATO pump to work with the hydros drive port. Just pickup a Hydros Drive Cable. Cut the cable and attach it to the Tunze pump.
Good to know! I saw the pump spec somewhere was good to 12V and just assumed it would work. Thanks for clearing that up!Unfortunately, that cannot be done because the Tunze Pump runs best somewhere between 4-9 volts. If you run it at 12V, it creates too much starting load for the power supply inside the Control. For that reason, you cannot put it on a drive port since it will run the pump at 12V.
One option is to connect the pump to a variable voltage power adapter and set the power supply to 4.5V depending on how high up you are pushing water.
Connect that to an outlet on a WiFi Strip and run it.
