Using Direct Drive with Varios-4 as a Return
BeccaBits
St. Louis, MO
What’s the proper way to configure a Varios-4 as a return using Direct Drive? I was surprised that when I selected “Return” as the “Type” that the only outputs shown were the 0-10v.
What I have done is the following:
Type = Flow Pump
Model = Varios
Speed Range = 0-75
Output Device = Direct Pump 1
I then created a Schedule with:
Pattern = Constant Speed
Speed = 100%
…and left the other settings alone.
This seemed a little clunky for a return pump, so I wanted to make sure I was doing the right thing.
That may have been the only outputs available for that type of output. I use the return output with a regular AC style pump that is plugged into a wifi strip outlet. Since I don't use a schedule with a return pump I cannot tell you exactly how your setup will run. If it does it will be at 75% since the schedule has 100% and the max set for the pump is 75%. I have not tried using the schedule without setting times and other settings.
Yea it looks right.
Also you selected direct pump 1 that is not 0-10 v so I am confused on that statement of only 0-10V.
In Patterns make sure you select the pump you created in outputs.
Danny's is right on the speed.
Type = Flow Pump
Model = Varios
Speed Range = 0-75
Speed = 100%
Yes, that is the correct way to do it. Remember, the WaveEngine is not designed to run pumps at one speed. It can, but it is overkill to create a schedule for something running the same 24/7; however, we understand the appeal of removing the power supply.
BeccaBits, I have a similar setup using the Varios 4 as a return pumps and a Varios 2 has the driver for a closed UV loop. I also setup my V4 and 2 the same way you did. Are yours functioning?
I ask because I cannot get the WE to run using the direct drive despite a replacement WE and power supply. I waiting for some replacement direct drive cables but after 3 weeks+ which has involved, ripping apart my control panel setup and a lot of time on the phone with CV, I'm about ready to throw in the towel and use the native controllers and power supplies. Rob
RobT,
I have the exact same setup and have no issues running the Varios-4 and Varios-2 off of the WaveEngine. Since I am only running two IceCap 2k Gyres of the WaveEngine, I figured why not lose the two power supplies and controllers.
Rural R, Thanks for your input. I hope to have replacement direct drive cables late Monday so I am hoping I just received a batch of defective cables as I and CV have tried about everything else over the past 3+weeks. To try another tack, I have even ordered another direct drive cable from another supplier as well as the -10 volt adapter cable. Unfortunately when BRS killed Marine Depot, I lost a reliable quick shipper who carried CV products i.e. I live about 3 hours away from MD. So ended up ordering from Premier Aquatics but I won't get them until Monday. Rob
Rural Reefer, or Becca bits: What version of the WE are you using? Mine is the WE with the wifi card and eco-tech compatible version.
Does the pump work with the original controller?
I have had bad cable before it does happen so it maybe the cable.
I have 2 WE and all three run a VaRios pump just fine. I do it so I have less power supplies and also one place to shut it all down.
Did you clean the pump recently? Has it been out of water for a bit?
Shred5, Are you using the WIFI Eco- Tech Version?
I have spent hours on the phone with Coral Vue Tech. The pumps are brand new and I have run all three (two Varios 2s and one Varios 4) on their native controllers. They work fine. As this is a new tank, they have yet to be run in saltwater. I have had a replacement WE (WIFI) and power supply sent to me. I have gone through now 6 cables, I have replaced the power cables, I have changed outlets, etc. Coral Vue Tech rep has set up and verified the setting by operating the WE from their end.
Yes, I understand the appeal of the direct drive WE i.e. elimination of PS etc. It is why I purchased the WE in the first place. I also have to Octo Pulse 2 Wave makers but again no joy.
