If you are typically dosing volumes smaller than optimal for the native 40ml/min rate of the Hydros Drive Port Doser, I’ve got a simple solution for you. Amazon sells a bunch of different 12VDC PWM motor speed controllers for really cheap (under $10). You can use one of these to reduce the speed of the dosing pumps DC motor really easily.
This is the model I used PAGOW DC Motor Speed Controller... https://www.amazon.com/dp/B08G4PQ2FW?ref=ppx_pop_mob_ap_share
All I did was hack it into a Drive Port extension cable I had and bingo. I was able to get the pump down as low as 5ml/min. Although I don’t recommend maybe running it at the lowest limit in case the motor stalls.
Just wire the controller in line and you’re good to go. If your handy you can even modify the doser itself and integrate it internally.
I haven’t tested the long term reliability or consistency of this solution but I wouldn’t expect any issues but something to check from time to time with recalibration.
