christopher.issler
I'm working on building a probe that achieves the following goals, possibly some are outside the current scope or capabilities of the software, but it's nice to hope...
1. Grounds the tank using a titanium probe to ground, to suppress any EMF created or stray voltage that made it's way into the tank by damaged or worn equipment.
2. Measure the Amps and Volts across the ground probe to the ground.
3. Leveraging the 0-10v inputs, measure the amount of amps/volts across the line. Perform the following...
A. If amps/volts are too high, based on static boundaries, alert the user via notification.
B. Trend volts/amps, abnormal increases compared to normal trends, send notification.
C. (A dream)Have a diagnostic tool, which completely powers down all devices, looping from this point on, pause 5seconds, then power each device for 30seconds, and sequentially powers up each device. To try to identify a piece of hardware which was is causing increased amp/volt spikes. Measurements are logged ever 5 seconds and logged in an output screen.
Some assumptions.
1. This device and capability in no way is intended to replace a GFI.
2. A single grounding probe should be able to be connected to each tank/body of water where a heater/pump is submerged.
3. The panel is not neutrally grounded.
4. The ground lug on an XP8 is not monitored currently in anyway. If it is, a probe to the 0-10v could be used and grounding could be done on the 110v ground leg on a Xp8
Some assumptions.
