Vortech Drive - Feed mode speed
Jakerupe
St. Louis
Is there a way to adjust this on the feed mode to completely stop? The way they communicate out of the box and in this slave state works fine when I want to feed my fish. The issue is when I am trying to spot feed my corals. The app says that the vortech is at 0% however it stays on at a very low rate but enough that it scatter the reef-roids a little to fast.
Right now I don't have the main pumps connected to the Wavemaker so I have a separate feed mode that I use for the power strip to just shut off these pumps and I added the vortech to that.
Just seems that I am missing something that seems so simple. Also I am curious if others are using the wavemaker to control their MPs or if they have utilized more of the advanced Mobius features. I plan on adding a controller when I figure out which of the 3 will work best for me.
There's not. its I THINK a limitation on ecotech side. My solution is going to be plugging the mp60s into an outlet that when in feed mode turns off. Sounds like the same thing happens with Apex and mp60s. 0 isnt realllly 0 its like 10.
I just hope the update includes mp60s in the pump options list instead of the wonkiness' it is now
Ya that's the same spot I am and I know that the Hydros controller can hook up with my WiFi strips so that is the next step is figuring out which Hydros Controller.
Just wondering since I am switching between apps anyway if there is a reason not to upgrade the MP40s to the new drivers and use the mobius app for all the different modes. I am assuming though that I can add outlets from the controller to the Feed mode as it is on the Wavemaker.....
You could do what you taking about in your second statement. You could use mobius and the new controllers with all of ecotechs wave modes and have them plugged into an outlet and when you are in feed mode they turn off. Very doable.
