Would it be possible to add an option within the Flow Pattern Schedule profile to "Invert Rotation" for a set schedule? Right now you can do it at the output level, but then any schedule program you run will just run in reverse (with the exception of Gyre since it runs both directions if allowed). I have seen some users want to run a Gyre type pump in forward and reverse using other schedule flow patterns based. This is handy for example if you run a forward pattern most of the day (constant, sine, etc) then for 30 mins overnight, you reverse the pump direction and run it constant at full in reverse to either clear the pump head or detris from a tank bottom. Adding a "Invert Rotation" option in addition to the Flow Pattern Schedule profile would allow this. The setup would look like this:
Output Pump Profile:
Gyre - 4K
Invert Rotation - Disabled
Allow Reverse - Enabled
Day Schedule:
Flow Pattern - LPS Reef
Schedule - 00:00:00 - 23:30:00
Allow Reverse - Disabled
Clean Schedule:
Flow Pattern - Constant
Schedule - 23:30:01 - 23:59:59
Invert Rotation - Enabled
With current controls the invert rotation is fixed for all schedules on 1 pump, it would be helpful to have it per schedule.
Gyre - 4K
Day Schedule:
Clean Schedule:
