That is a bug that we just encountered. It has to do with you adding the Alkatronic input, but you did not finish configuring it. On the gray screen, tap on the upper left-corner hamburger menu and select INPUTS. Then choose your Alkatronic input and finish setting it up. Select the serial number and set your high and low ranges, as well as your notifications. Upload the changes, and then you will be able to access the status screen.
We are going to push an update to fix that problem, but this is the workaround. Again, we are genuinely sorry for the inconvenience.
