I've currently attached my collective to two different Wi-Fi access points. I used to run it on a mesh and a dedicated IOT band, but none of them seemed to be able to maintain constant connectivity; I started getting updates and sync issues that have progressively gotten worse with each device added. Does anyone have a solution for large collectives and system changes? Is there any possibility, Coralvue, of adding a wired ethernet gateway device or function to route the communications over the command bus and out through a physical connection?
Any help will be appreciated,
Regards
Rob L
Regards
Rob L
