When it comes to protecting the XP8, the only vulnerable component is the internal Meanwell power supply, which is quite resilient.
Understanding the differences between the three official types of surge protectors-Type 1, Type 2, and Type 3-is key to selecting the right protection for your home. Here's a breakdown of their unique features:
- Type 1 devices safeguard your entire home and are typically installed at your power meter, connecting to the LINE side of the main circuit breaker.
- Type 2 devices also protect your entire home. They are usually installed at your main circuit breaker panel and connect to the LOAD side of the breaker.
- Type 3 devices are designed to protect specific circuits, and most people are familiar with these as plug strips.
While having all three types of surge protectors is the ideal scenario, it's important to note that it can be a significant investment. Type 1 and Type 2 devices require professional installation.
A general recommendation is to install a Type 2 surge protector, which can cost around $500 and provide protection for everything in your house from most surges. If you have highly sensitive equipment, adding a Type 3 protector near it is best. In most households, the most sensitive equipment is a large-screen TV.
If you are concerned about the XP8, you can install a basic plug strip-type surge protector, making sure it is not exposed to water or moisture. While we considered adding surge protection to the XP8 itself, the issue is that the small varistors used for Type 3 surge protection have a relatively short lifespan. It is easier to replace an external surge protector than to replace the XP8.
