BAMatter
My collective will be a Control 4, WaveEngine, and XP8 (patiently waiting for this part)Before I answer that question, do you just have a WaveEngine or do you also have a Control module?
If I can’t do it all with the WaveEngine can I put the door switch on the C4 and the Varios on the WE?Ok, good. AFAIK, you couldn't do what you want with just the WaveEngine, even though the physical connection would be the same.
Two options:
Option A)
- Door switch <-> CABLE #1 <-> WaveEngine 0-10v INPUT
- Varios 6 Controller <-> CABLE #2 <-> WaveEngine 0-10v OUTPUT
Option B)
- Door switch <-> Jeff's custom breakout box
- Varios 6 controller <-> Jeff's custom breakout box
- Jeff's breakout box <-> WaveEngine 0-10v INPUT & OUTPUT
I could be wrong, so hopefully, someone else can chime in here. My understanding is that as long as you have a Control in the collective, it doesn't matter which device things are plugged into (so long as inputs & outputs line up as described above). So yes, you'd be able to plug it all into the WE or do the split, whichever is more convenient. My caveat was simply to make sure you weren't running a WE-only setup (which is what I have).If I can’t do it all with the WaveEngine can I put the door switch on the C4 and the Varios on the WE?
Ahhh ok. Thanks! Appreciate ya…I could be wrong, so hopefully, someone else can chime in here. My understanding is that as long as you have a Control in the collective, it doesn't matter which device things are plugged into (so long as inputs & outputs line up as described above). My caveat was simply to make sure you weren't running a WE-only setup (which is what I have).
I would be interested in this. Care to point me in the right direction please.How handy are you with a soldering iron? They're not too difficult to make and I could walk you through it if you want.
Sure, can you share what sort of experience you have? Covering the basics, you'll need:I would be interested in this. Care to point me in the right direction please.
