Can you post a picture of the flow sensor you have ?Hello, I installed the hydros flow sensor. When adding it to the inputs what flow rate model do I select?
Fm 025. Fm 050 fm 075
It gives different readings according to the model I select and FM 025 gives a flow rate that can't be right.
You're very welcome. Make sure to clean it at least every 3 months or so.Thank you very much....that number looks much better.... although as per UV I need to be at 214 gph..... for parasite control. I'll turn up the pump see if I get more through my manifold.
