Adding a Varios 6 to the Wave Engine
kbrooks
South Florida
I am changing my return pump to a Varios 6, and want to connect to the Wave Engine; what do I need and how do I set up the 0-10v ports?
0-10v you would still need the pump controller.
If you want to hook it directly to a direct drive port you need the cable below.
This will allow you to eliminate the controller and power supply.
HYDROS Reef Octopus Varios 2/4 & OctoPulse 2/4 WaveEngine Pump Adapter
SKU: HDRS-WE-OCTPA
gotcha, was hoping to get rid of all that... but it will be fine.
thank you for your help
One good thing about keeping the various controller is that they can run independently if ever needed. Just unplug the 0-10 volt plug. It's the way I have my return pumps set up on purpose.
Ok sorry yea the 6 is only 0-10v.. I read the last post.
There is a port on the bottom of the VarioS controller for 0-10v. You need the controller and power supply for that.
The adpater cable for the WE has 4 cables where do they all go? One goes to the controller (which one) and the rest. Kinda feeling a little stupid on this one.. thank you for your help
Update: i watch the video again. i think i got it. Will update tomorrow.
This page here should have all the info you need:
If you have more questions feel free to ask here.
It is so it can control 4 different pieces of equipment.
With my test unit I was running two pumps on 0-10v so I used 2 of those cables.
