I'm considering using one of the four 0-10v inputs to control my auto top off. There will be three float switches hooked to a single 0-10v input through a voltage divider. the voltage divider will create a 3v input when the low level switch is closed, then a 2v input when the low and fill float switch are closed, and 1V input when the low level switch, fill switch, and overfill switches are closed. In this way I don't need to use multiple o-10v inputs for each switch.
Here is my assumption - I can trigger different outputs for three distinct voltages on a single 0-10 volt input channel. Is this true? Has anyone done something similar?
Also, it would be nice to be able to trigger a message if I had some odd voltages. This could allow additional diagnostics for failed switches. So my question is - what are the allowable voltage trigger points, only 1V, 2V . . .or can the triggers be set to 1.5V. . . ? What's the trigger tolerance e.g. 1V +/-.2V?
My circuit is below. I can provide resistor values for anyone who may be interested.
