Danny
I use 3 of my 6 drive ports for dosing pumps. They are not the Hydros dosing pumps. I do have a Hydros pump ordered and will try it out as my ATO once it arrives. I am hoping it will fit where the other pump is now. I have a X4 and two X2's for the drive ports. It will take CoralVue and Kamoer together to allow Hydros to access the Kamoer pumps. That would be nice if it does happen, but it can be accomplished with 4 Hydros dosing pumps if you have the drive ports to use.Yes I know I watched the cvtv workshop. To give you an idea I dose Aquaforest 123+ which uses 3 heads, plus I am dosing Nitrates with the 4th head. I got the X3 controller that does not have a drive port so my only option is to use a dedicated power bar for 4 single head pumps and honestly they are not convenient to mount on a control pannel + plus additional wires etc... I work in IT as a Sales Engineer for a software company. I am not an developer by any means nor am I an API specialist but from what I understand from my developpers, anything in terms of feeding data between 2 software can be done if they are both using the same API. As the command ports on the Hydros use CANbus to share data, and that the Kamoer F4 Pro has CANbus connectors, I am just suggesting that this would be a nice feature if the Hydros could be used as the programming interface for the smart doser. A single pane of glass for everything. As there is a partnership between CV and Kamoer, maybe this is something already in the works, and if not maybe they can consider it... I know I would buy a F4 if I was able to interface it with the Hydros. If not, I might buy a RedSea ReefDose or another brand of Smart Doser or just keep the one I have if I have to use it as a standalone and in a different app anyway...
