Hey Dmytro,
Couple of quick questions. I am looking to build on of these. Since you can calibrate the flow rate in the schedule what is the purpose for the flow adjusting knobs? Similar question about the buttons since we are using 10V output off of Hydos I don't understand what the buttons would be used for? Not Trying to critique just genuinely wanting to understand the workings of your set up? I like the idea of more flexibility just curious how it all works. Thanks!
I can't speak for Dmytro, but the reason I've seen that a lot of people use the dials is for smaller doses.
Say you get a 12v dosing head that does 25ml/m. Hydros can have up to a 2.5 second "lag" for turning the pumps on and off, so your minimum dose would be 25ml/m, divided by 60 seconds in a minute, times the 2.5 second "lag", or (basically) 1.04ml. So that is the smallest dose you can have with that pump running at 12v.
Now if you dial the same pump to 40% speed (4.8v), or 10ml/m, that same 2.5 second dose time gets you a .42ml minimum dose.
You might need big doses for alkalinity or calcium, but you may only need tiny doses for things like trace elements. So, depending on what you're dosing, you can use a faster dosing head and just dial the speed up or down to accommodate your needs. Make sense?
I kind of accomplished the same thing by getting 3v, 5.4ml/m dosing heads and using buck convertors to reduce the 12v input to 3.3v. I knew I'd be dosing smaller amounts for this application, and this allows me to get down around .2ml individual doses if needed. I could've used faster heads and dialed them down, but it adds more complexity, extra parts and extra wiring. I wanted to keep things simple, and I can always let it run longer to get more if I need to.
