DIY Terminated Power Supply
Syracuse NY
This tutorial will go over how to install a termination resistor in your hydros power supply connector so you do not need a dongle version. This is handy in cases where you have a data only cable between two hydros devices in a collective.
what you need:
- 24v hydros power supply
- 1/4watt 120 ohm leaded resistor
- electrical tape or shrink tubing
- soldering iron and skills
first remove the 2 screws a the collar. Then spin the housing from the connector head and slide back down the wire to expose the gx12-5 pins
cut your 120 ohm resistor as follows
then solder the resistor between connector pins 2/3. Pins are labeled on the face of the black connector for reference
Either wrap the exposed resistor with a small piece of electrical tape or heat shrink to prevent contact with metal connector housing
reinstall housing and screws
test resistance between connector pins 2/3 with an ohm meter. Then plug it in and measure 24vdc across pins 1/5. Then your good to go!
what you need:
Hi Jeff,
Thanks for posting stuff like this. But,,,,, just wanted to make sure I am understanding. So I can also do this to my power supply for a normal collective not involving a data cable. Say if I have a control 2 and a control XS in a collective I can install the resistor on the power supply going into the control 2 and won't need the terminator on the connected XS? I always question my electronic knowledge. Building things is easy for me but electronics throw me a bit.
Thanks.
John
It is best if a collective has 2 terminators, with one at each end of the link. Still, for a small collective, 1 terminator would work, and yes, if the power supply has the terminator incorporated into it, then that is the 1 terminator you need.
Thanks Carlos
