- Admin
- #1
Firmware 242 is now available for the following devices:
Installation Instructions:
Step 1: Download the new version of the app from your app store
Step 2: Download and install the latest firmware version. You must download App version 2.3.4 first BEFORE updating to firmware 242.
Please visit the CoralVueHYDROS.com website for more in-depth instructions on downloading and installing the new firmware.
Full Changelog
- Control X4
- Control X2
- Control XS
- Control X3
- Control XP8
- WaveEngine
- WaveEngine v2
- WaveEngine LE
- IceCap WiFi Controller
IMPORTANT:
NEVER, EVER, EVER update your firmware if you are not in the same location as your controller.
- All outputs will default to AUTO when upgrading from firmware 197 to firmware 242. If you previously manually set any outputs to ON or OFF, you MUST manually reapply/change/override them after upgrading.
- All reservoir values will be lost when upgrading from firmware 197 to firmware 242. You must manually set the volume again.
Firmware 242 requires App 2.3.4. To update to firmware 242, you must first download App 2.3.4 from the app store. If you are using the web app, please clear your browser's cache so it updates to the new app as well.
On Vacation and Need Access to App 2.3.2?
If you are on vacation and cannot update the firmware right away, you can always access your devices via the Web App (Previous). Note that if you update the firmware, you will not be able to use 2.3.2.
Full Changelog
