I am trying out the new AWC output on my freshwater tank. I can make the ATO work & I can make the AWC work, but I can not make the AWC/ATO work because I can not use the same output for both the Fill and ATO function. Since freshwater means my ATO and Fill water are the same source, I would like to only have 1 pump to deal with both operations. I understand that filtering out the outputs from being selected multiple times can act as a safety precaution and prevent confusion. I propose adding a checkbox to designate when the ATO and Fill are to use the same output. Perhaps right below the Drain output field?
