DigitaLSD
Every time my iV runs a test (every 4 hours) I get this notification on my phone, any ideas?
Have you tried using the web app and doing a upload changes?Every time my iV runs a test (every 4 hours) I get this notification on my phone, any ideas?
I opened it up, there's no "upload changes" button. I had problems when I first updated inside the app, I had to re-setup all of the inputs, and I uploaded changes after that, all in the app, and it worked just fine...Have you tried using the web app and doing a upload changes?
other than this constantly repeating error...I opened it up, there's no "upload changes" button. I had problems when I first updated inside the app, I had to re-setup all of the inputs, and I uploaded changes after that, all in the app, and it worked just fine...
Click on the right menu and it is in the menu.I opened it up, there's no "upload changes" button. I had problems when I first updated inside the app, I had to re-setup all of the inputs, and I uploaded changes after that, all in the app, and it worked just fine...
Did that at around 8:45pm last night, test ran at midnight and still got the error... It's run two more times since then, and the error has been present both times... It does seem to come AFTER the testing is complete...Click on the right menu and it is in the menu.
Yes, the new firmware will not allow a name to be used more than once and it will change one of them. Usually the safest one to change is the output if the other is a input. That will break anything that uses that output such as schedules, depends on settings and used as a input in a combiner output. I thought I had all of mine different and it found some when I updated but I think I found them all and got anything corrected to the new name.@Danny I *think* I might have figured it out... I found it strange that my iV was named iV-2, and when I went to change it back to just iV, it said I couldn't because there was already an iV present... So I dug around and found an iV under inputs. I deleted it because it was set as a probe and I already have iV pH, iV Alkalinity, and iV Salinity setup as Inputs... so we'll see how it goes... I'll touch base after 1pm Central to see if the notification happened again...
Well, it worked... No more error... However, I noticed a few other things, I went to go calibrate my pH probe and that was all jacked up in the system too... I'm 1/2 tempted to just shut everything down and restart it from scratch setting up all of the individual things again just so I can be certain I don't miss anything else...Yes, the new firmware will not allow a name to be used more than once and it will change one of them. Usually the safest one to change is the output if the other is a input. That will break anything that uses that output such as schedules, depends on settings and used as a input in a combiner output. I thought I had all of mine different and it found some when I updated but I think I found them all and got anything corrected to the new name.
That is odd I did not have any issue with pH calibration on my pH ports and one is used in the iV.Well, it worked... No more error... However, I noticed a few other things, I went to go calibrate my pH probe and that was all jacked up in the system too... I'm 1/2 tempted to just shut everything down and restart it from scratch setting up all of the individual things again just so I can be certain I don't miss anything else...
