BAMatter
Hi all... I currently run an InkBird 306 with 2 of the BRS Titanium 300 watt heaters, plugged into an ADJ PC1000 power strip. Each of the heaters is rated at 2.5 amps, and I believe the InkBird is .8 amps. Each of the ADJ channels can supposedly handle 10 amps. Came home to a dead channel the heaters were on, I’m assuming it couldn't handle the on/off surges even though rated below its max. That said, is the XP8 designed for applications like heaters? If so, what is different about my current power strip and the XP8 that makes the XP8 able to handle things like this?
thanks!
thanks!
