This post will serve as a summary page for commonly used DC (direct current) reefing equipment that can be used with the Kraken. Note that the information provided here is for reference purposes only. Please post below devices you have used and found to work on Kraken and I will update these tables with that info. If something isn't listed here, it doesn't mean that it won't work with the Kraken, just that it hasn't been asked/investigated. If you have a device that you are wondering if it will work with Kraken, please post below (include picture of the back of the power supply and the DC plug).
Force Port Devices:
Note: Kraken force ports can provide up to 10A/240W each but ALL devices on a Kraken together must not exceed about ~450W (margin for controller itself and bus power). Also note that while on battery backup power, the kraken will only output 12VDC on the 24VDC Force Ports - not all DC devices will run at this lower voltage but many do (at a 50% reduction in power). There are some DIY* options to enable 24V output always on a force port but requires external boost converter. Tutorial on how to use one of them will be posted soon.
Drive Port Devices:
Note: Kraken drive ports can provide up to 1.5A/18W each but ALL drive devices on a Kraken together must not exceed 36W total. On battery backup, a kraken drive port will run at about 11V
Full list of devices is HERE: Kraken DC Device List
For devices that use 5.5x2.5, use one of these to adapt standard Force/Drive port Hydros cables: Amazon.com
Disclaimer: Note that this list is for reference purposes only, I am not an employee of Coralvue nor of any of the companies listed within, this information is being provided to help you figure out what devices MAY run on the Hydros Kraken. I take no responsibility for any damage to any equipment in any case. Information compiled in this sheet is correct to the best of my knowledge but errors/typos may exist. Please do your due diligence in researching how to use Kraken Force and Drive ports and if you have questions please reach out to Coralvue Support at support@coralvue.com
Force Port Devices:
Drive Port Devices:
