nbarbier79
Even if I run my pumps 24/7? With the exception of doing a water change of course.You should have a schedule for them to run.
I don't see the test pump under the pump option. The only thing that is available is the name I chose for each pump, in my case, Gyre 1K and Gyre 2K.No problem glad to help. Also on the pump settings if set the minim and max settings the settings in the schedule will be a percentage of those. In the case below 0% on the schedule would actually be 20% for this pump. Also 100% on the schedule would be 86% on this pump. That way you can use the same schedules for more than one pump but still set a different min and max for each pump. I assume no all the settings are in each pump setup.
