Harper
I purchased the x10 and IV couple months ago to replace a failed alkatronic. I have been unable to get consistent results. Previously, and currently with manual hanna tests, my alk would increase after the lights go out and decrease during the day light. The hydros will show a reading that is within expectations then for 2 readings jump really high. Then return to expected. The 2 high readings seem to happen randomly sometimes there is also a single really low reading. Middle of the night, mid day, or any time. It doesn't follow any pattern, and the readings are off compared to Hanna/other testing. I turned off my calcium reactor which should have lead to a consistent down trend but instead the hydros had this random ALK.increase.
The x10 unit is hanging attached to the 8020 at the top of my stand (underside of aquarium) with the IV and reagent at the bottom of the stand. Pic attached. Also pic of hydros app readings and pic of spreadsheet with alk readings over time.
I am using the coralvue concentrated solution. I expect my preperation to be off a bit which it was with the alckatronic but the repeatability would be consistent.
I have calibrated everything several times and they maintain calibration. The IV pH tracks with the sump and salinity is spot on. I have tried my best to place the reagent tube and pH probe at the proper heights in the IV.
I'm thinking it might be some inconsistency with the dosing pumps. Since the x10 has 1 extra doser I was thinking of moving the reagent to the 4th head. Let the test run for a day or so. If the doesn't change then cycle through each head.
Any suggestions?
Any suggestions?
