John Neuzil
Did anyone else loose the 2 and 3v input buttons when they updated to 177?
Yeah, check above under options what your Mode Control Input is set to. Are you using a single Control 4 or have a collective?I've been using the 2v for feed mode and the 3v to turn off my ato in a mode.
Yes it's reading 2 and 3 on the correct button.I am updating my Control now to check- as far as I know nothing should have changed.
You can troubleshoot the input by creating an analog input on the channel the switch box is plugged into. Leave the scale at 1, and no offset. Once you upload this, you will have a live reading of the voltages applied by the breakout box. Can you verify it is reading 2v and 3v when the appropriate button is pressed?
Edit: or double check in options that the mode control input is *Still* correct after the recent update.
CollectiveYeah, check above under options what your Mode Control Input is set to. Are you using a single Control 4 or have a collective?
Nope, didn't work.I know with 177 they updated the 0-10V input selection for MODES under the options tab, this was mostly for collectives where you could now select which control 4 the input was being used from. This wasnt an option under 165. So you might want to check under Options where you specify "Mode Control Input", and change that to something different, upload, and then back to the input you are using for modes (if you are using buttons for modes). This may correct something in the configuration if it is this.
Interesting, I will have to check this tonight. I have 177, a button box, and a collective. Only thing I have noticed is that if you are already in a mode, like feeding and you try to use a button trigger to go to another mode, it wont trigger. Buttons only seem to work when you go from Normal => another mode.Collective
Yep. And it was working fine before the up dateHow long are you holding down? Tried 2-5 seconds?
I just checked on another stand alone control 4 I have with 177 and I could get 2/3v to trigger modes fine. Go into your modes and check the voltage ranges haven’t changed for triggering those modes.Yep. And it was working fine before the up date
All set they way they should be.I just checked on another stand alone control 4 I have with 177 and I could get 2/3v to trigger modes fine. Go into your modes and check the voltage ranges haven’t changed for triggering those modes.
Not yet, but I will try that this afternoon.Not sure what could be causing the issue, but presumably the box itself is working because you can see the applied voltages correctly.
I have one other suggestion in my playbook. Did you try turning it off and on again?![]()
Rebooted the Hydros and no change. Toggles work but not the bottonsNot sure what could be causing the issue, but presumably the box itself is working because you can see the applied voltages correctly.
Hi Harold,Not sure what could be causing the issue, but presumably the box itself is working because you can see the applied voltages correctly.
