Hey everybody. I just setup my IV. I used a Blenny for the dosing pump because I already have a Launch with an available PH and Conductivity ports. I got everything setup according the Hydros instructions, calibrated the PH and Salinity probes, calibrated the dosing heads, primed all the lines.
I keep getting an error message about 5 minutes into it. When I start the test, it drains the beaker, fills it up, drains it again using the fill doser?, refills it and it just stops. I see the stirrer spinning so I know that works. My log says that it's dosed .2 ml of reagent. When it quits, it's still full of water and doesn't drain until I restart the test. Any ideas of what's happening?
