ReefBrite XHO
  • Thread starter Thread starter tdg910
Correct. You’d need to split the ground from the single side of the APX rj45 to both grounds on the reefbrite RJ45
I actually got the APX to Kessil RJ45 adapter to work with a coupler but that’s because they use 1 ground and 2 signals on a TRS 3.5mm phono plug. So no sep grounds needed.
That would probably be the better way to do it. Less likely for someone to connect the wires in the wrong place.
