Hey folks.
I’m looking to setup a “semi automated” water change. That is, rolling a 30g saltwater brute can and an empty brute can up to my tank. Then fill from the saltwater can and drain to the empty can until the saltwater can is exhausted.
I setup an AWC config with the ATO part of the config disabled as I want that separate as it’s not a fully automated water change.
I’ve been testing it without water using the logs to see if it is doing what I expect and seems to work ok by using the water change mode to activate the AWC and deactivate the existing ATO config I have already setup.
Question is after filling. The logs indicate that it goes into a wait state for 10 min. Then an idle state for a couple minutes after that. Is there any way to change that wait and idle state as I would like a 30 gallon water change to complete as quickly as possible?
Or maybe there’s a different approach I should think about using ?
Thanks
Thanks
