It is a part of the generic output type and has been since the Hydros was released. All you have to do is use the generic output type instead of the skimmer output type and the turn on has schedule and it will let you set a on time and off time. If you enable advanced settings on the output it even allows for multiple off and on times as long as they are all equal and happen a even amount of time apart. The skimmer output type is for someone getting started and makes it simpler to setup but almost any output can be done with the generic type or combiner type or a combination on more complex setups. Also even though it is the generic output type you can set the icon on the output for the skimmer output so unless you go into the settings you would not know the difference between the skimmer output type and generic output type.I would really like to see this too. Seems like a super odd feature to be missing, especially 3 years after the request. It's nice to have a work around, better to have a native solution. No reason it should be difficult to add scheduling to every device within device properties. Simple scheduling should be part of any controller setup from day one, and while I have really enjoyed the Hydros, this is a weird and annoying oversight.
I apologize if it's already been added and I don't see it.
Hey thanks for the tip about the icon, I love that! That satisfies my OCD.It is a part of the generic output type and has been since the Hydros was released. All you have to do is use the generic output type instead of the skimmer output type and the turn on has schedule and it will let you set a on time and off time. If you enable advanced settings on the output it even allows for multiple off and on times as long as they are all equal and happen a even amount of time apart. The skimmer output type is for someone getting started and makes it simpler to setup but almost any output can be done with the generic type or combiner type or a combination on more complex setups. Also even though it is the generic output type you can set the icon on the output for the skimmer output so unless you go into the settings you would not know the difference between the skimmer output type and generic output type.
