It is a part of the generic output type and has been since the Hydros was released. All you have to do is use the generic output type instead of the skimmer output type and the turn on has schedule and it will let you set a on time and off time. If you enable advanced settings on the output it even allows for multiple off and on times as long as they are all equal and happen a even amount of time apart. The skimmer output type is for someone getting started and makes it simpler to setup but almost any output can be done with the generic type or combiner type or a combination on more complex setups. Also even though it is the generic output type you can set the icon on the output for the skimmer output so unless you go into the settings you would not know the difference between the skimmer output type and generic output type.I would really like to see this too. Seems like a super odd feature to be missing, especially 3 years after the request. It's nice to have a work around, better to have a native solution. No reason it should be difficult to add scheduling to every device within device properties. Simple scheduling should be part of any controller setup from day one, and while I have really enjoyed the Hydros, this is a weird and annoying oversight.
I apologize if it's already been added and I don't see it.
Hey thanks for the tip about the icon, I love that! That satisfies my OCD.It is a part of the generic output type and has been since the Hydros was released. All you have to do is use the generic output type instead of the skimmer output type and the turn on has schedule and it will let you set a on time and off time. If you enable advanced settings on the output it even allows for multiple off and on times as long as they are all equal and happen a even amount of time apart. The skimmer output type is for someone getting started and makes it simpler to setup but almost any output can be done with the generic type or combiner type or a combination on more complex setups. Also even though it is the generic output type you can set the icon on the output for the skimmer output so unless you go into the settings you would not know the difference between the skimmer output type and generic output type.
The generic output type is for more advanced setup of an output. The Skimmer type is for getting a skimmer up and going with the most common type of setup for one. If you want to control with more than a skimmer level sensor for shut off when full then you would use the more advanced generic output type for that. With it you can use up to 9 inputs and a schedule if you want to control it. All you have to do is switch the family setting to advanced and then set type to generic and then fill in the added settings. The rest of the setup should still be there. Then click on the pen in upper left of the settings and this will bring up a popup for either changing the name of selecting a different tile icon. Below is my full skimmer settings except for the active in modes settings I did not expand them for the screenshot. I do not normally setup a schedule on my skimmer but I turn it on for the screenshots since that was what the thread is about, I do have three inputs that control my skimmer. The first is a sump level high sensor. The second one is a leak detector in the stand where my skimmer collection container is at. The third is a sensor in the collection container. I use the AND combiner type so all three inputs have to be in the active state before the output is allowed to turn on if the other settings are also satisfied. One of them is the schedule which in this case it would have to be between 10am and 8pm for it to be on. It also has a minimum off time setup to 10 minutes so if it does turn off it will not come back on for at least 10 minutes from the time it turns off. The exception to this is if the depends on setting forces it off then the 10 minute countdown starts when the depends on becomes no longer active. This output has the depends on set to the return pump. The dependency mode is set to off if off. So if the return is turned off the skimmer output is also turned off.It's great that there's a work-around for this.
But what would be greater, is if each output had the scheduler feature and the end user didn't have to google for an answer and work-around. As a software developer, my expectation when I received a Hydros was that the interface would be constantly improving.
I realize that my two posts so far sound like "get off my lawn," guy, but while this software is tremendous, it could be better and any speed bump that limits the end user's ability to quickly and intuitively configure their equipment negatively impacts the end user which impacts adoption (and sales) of Hydros.
I want this eco-system to blossom.
