Temp Probe Interference
Thanks Jeff. I know, I could do this, however, I wanted to update here to see if either 1) It was some error on my part or 2) to give the engineers a heads up on a issue they may need to investigate.
This will all go away once I pick up another C4, C2, or XS for the basement and won't have to run an extension cable to the sump. Do the new units come with a power supply with a terminator built in or you have to buy that separately?
BTW... when you going to get more of those Temp/Humidity modules back in stock? ;)
New units will most likely come without a terminator, I know they are working through the existing stock that is the old style before going to all terminated. Your best bet of getting a starter kit with a terminated supply is connecting coralvue directly and buying from them. I believe they can swap it out for you if you need it.
Ugh humidity modules. I finally got part of my cable order but just haven't had time to build up the units. Summer and my day job (travel) has been keeping me from getting around to making those. I really hope I have some together soon! Really sorry it hasnt been sooner =(
