Octocat
I've had my control 4 and wave engine up and running trouble free for a few months now. Unfortunately, it seems my luck has run out.
Issue 1: I noticed yesterday that my temperature dropped way more than normally overnight. At some investigation, it turned out the wifi plug strip that controls my heater had lost communication with the control 4, but the control 4 continued to think it was connected. The plugs were also stuck in the off position- not on like stated by Coralvue. The problem persisted after re-pairing the plug strip. Luckily, I had another strip on hand and it is working.
Issue 2: Today, both my control 4 and wave engine stopped responding in the app. I tried resetting the wifi router and the units- no change. My alkatronic and kasa plug strips on the same network work fine. I can connect to both using Bluetooth, but the control 4 doesn't show any of my inputs or outputs.
I did install both the recent firmware updates for the control 4 when they were released. Is there anything else I can try? I am hoping to avoid a factory reset- I spend a lot time setting the control 4 up.
