- Admin
- #1
Firmware 186 and App 199 are now available for the following devices:
As always, you can also control your devices using our CoralVue HYDROS Web App. (Be sure to clear your browser's cache and refresh so that the app updates to the latest version.)
Release Highlights:
Installation instructions:
BEFORE you do that, please do read the following:
To update the WaveEngine to the new firmware:
You can now bring your WE into the collective, but before you do that, please know the following:
Once your WaveEngine is part of the collective, it will restart, and then, the LEDs will change to the same color as the Control units. Notice the green LED at the top of the unit letting you know the WE is now part of a collective.
If you see a white LED at the bottom of your WE, that means that you have a WE-ETM version!
Changelog for Monday, May 24, 2021:
- Control X4
- Control X2
- Control XS
- WaveEngine
- IceCap WiFi Controller
IMPORTANT: Firmware 186 requires App 199. To update to firmware 186, you must download App 199 first. If you are using the web app, please clear your browser's cache so it updates to the new app as well.
NEVER, EVER, EVER update your firmware if you are not in the same location as your controller.
Release Highlights:
- You can now add the WaveEngine to the Collective - HYDROS WaveEngine - Adding to Collective.
- RODI Preset with stateful is not available - HYDROS Control - How To Add a RODI Filter
- On the WaveEngine/IceCap Controller, Presets and Triggers have been combined into a single location called "Schedules" - HYDROS WaveEngine - How to Create a Flow Schedule - Help Page.
- Push Notifications are now available (replaces SMS notifications) - HYDROS Control - How to Enable Real-Time Notifications.
- WaveEngine Flow Patterns have been added to the Control, and you can use them with 0-10V pumps without the WaveEngine.
- Cloud backup and restore have been added to both WaveEngine and IceCap WiFi Controller.
- Pages have been added - HYDROS Control - Backup & Restore.
- Once you update the firmware and upload, you CANNOT downgrade the unit or revert to the old firmware.
- The update will automatically update the WaveEngine to match the way the control works.
- Pumps are treated as OUTPUTS. To add a pump, you go to OUTPUTS and add the pump to add a simple pump on the Control.
- PRESETS and TRIGGERS are now combined into SCHEDULES. The schedule will allow you to select a flow pattern, give it a schedule, and assign pumps to it the same way you assign INPUTS on a GENERIC OUTPUT.
- You can now run scheduled on certain days of the week.
- You can also now run schedules based on the Nth day.
- You can assign pump positions on the schedules so you can have one pump be "Same Side" on A schedule while "Opposite Side" on schedule B.
- You can now assign pump direction on the schedule, so if you want to run Pump A only in reverse for a couple of hours, you can do that now!
- Head over to the download firmware screen and tap on "Download 186."
- Tap on the "Install 186" button and wait for your WaveEngine to restart.
- After restarting, connect to the WaveEngine and go to the STATUS screen. IT WILL BE EMPTY! Tap on the "Upload Required" orange bar at the bottom. This will "convert" all your settings from the old flow to the new one.
- You must be running app 199 or greater.
- Your WaveEngine must be running firmware 186
- The WaveEngine CANNOT be a Collective WiFi Master, so set the WaveEngine to NEVER.
- When you bring your WaveEngine into an EXISTING collective, the WaveEngine will be imported EMPTY!!!! This means that you will need to program it again within the collective when you bring the WE into the collective. Unfortunately, there is no way around this, and it is in line with any devices brought into an EXISTING collective.
- Connect to your Collective and make sure you can see your STATUS
- Tap on the upper-left-hand-corner hamburger menu and then select "Devices."
- Tap on the + symbol at the bottom of the page
- Select your WaveEngine
- IMPORTANT: Set the WiFi Priority to "Never"
- Upload your changes
!!!! --- WaveEngine/IceCap Controller Warning --- !!!!
- Your old configurations will be automatically imported to the new Outputs/Schedule format. That being said, YOU SHOULD STILL DOUBLE CHECK SETTINGS to make sure things were properly imported.
- Once you update your WE/IceCap Controller to the new firmware, you MUST upload your changes. There is an orange bar telling you "Updates Required" so please, upload the changes when you see that orange bar! If you do not upload the changes, then the migration will not be completed!
- If you add your WE to your collective, ALL settings on your WE will be lost. Settings ARE NOT imported to a collective. Make sure to write these down before adding to a collective.
!!!! --- HYDROS Control Warning --- !!!!
- Water Sensor / Skimmer Sensor INPUTS - We added the ability to trigger an alarm when the sensors are WET or DRY. If you have a sensor created, please make sure that the alarm will trigger in the correct state for your setup.
- Collectives and Button Boxes - You must go into the OPTIONS menu and reselect the "Mode Control Input" so it is set to the correct device where your button box is connected to. Once done, upload your changes!
- [FIXED] - Purple reset did not wipe configuration from SD card
- [FIXED] - 0-10V INPUT showed red tile when open. Now user can select inside or outside the range for alarm trigger.
- [FIXED] - Repeating schedule not following run count limits
- [FIXED] - Various visual bugs on labels
- [FIXED] - Default notification interval is now 1 hour
- Added cloud backup ability to the WaveEngine and IceCap Controller
- [FIXED] - On 0-10V INPUT Switch, wording changes from "Active when" to "Wet when."
- [FIXED] - Multiple issues with WaveEngine migration software
- Added ability to specify "Low Power" mode on Options screen
- [FIXED] - When using 0-10V as OUTPUT, now you have the ability to set voltage range
- Added notification option to water sensors and 0-10V INPUTS
- [FIXED] - Variable output showing the incorrect minimum intensity when OFF
- [FIXED] - Uploads were very slow on larger collectives
- Added Push Notifications to HYDROS system
- Removed option for SMS notifications
- [FIXED] - Issue where customers registering their first product would get a "Bad Gateway" error
- [FIXED] - System triggers an alarm immediately if INPUT is missing due to reboot. Added a slight delay to prevent this from happening.
- [FIXED] - When using Button INPUT on Generic OUTPUT, both high and low thresholds were showing
- [FIXED] - Flow Pump Outputs would show on the Mode setup page
- [FIXED] - Issue where Direct Drive OUTPUT would report incorrect power consumption
- [FIXED] - Manual Single Feedings with the Feeder were not very responsive
- [FIXED] - On Feeder output, users could select outputs other than a Feeder WiFi Device
- [FIXED] - OUTPUT showed Mismatch when caught in between hysteresis. When in between the Range, ON/OFF depends on where the OUTPUT reading is coming from
- [FIXED] - Issue where 0-10V INPUTS did not graph
- [FIXED] - When creating a schedule, the pattern defaulted to "Constant." Now it defaults to none
- [FIXED] - On WaveEngine tiles, speed was being pushed off the tile
- Added running "Schedule" on flow pump override popup window
- [FIXED] - Fish Feeder WiFi device setup page was not reporting the "used by" field correctly
- [FIXED] - "Create Collective" button was pushed off the screen when the user sets the mobile default font to large
- [FIXED] - Purging old, deleted INPUTS and OUTPUTS from the JSON file
- Added ability to select All/None INPUTS and OUTPUT when arranging pages
- Added Dual TDS Sensor compatibility
- [FIXED] - Change wording under HYDROS Device description from "Internal Temp" to "PC Board Temp."
- [FIXED] - User was able to hide all tiles/text in a status section
- Added Terms of Agreement to the app when first opened. Sorry... our lawyers made us do it
- [FIXED] - When coming out of a Mode where the feeder was not active, the feeder would rotate once
- [FIXED] - Alkatronic tile did not turn red when reading was out of range
- Added JSON compression to help with large collectives and speed up the upload process
- [FIXED] - Issue where if you were looking at your system from two different applications, one device would go blank
- Changed Bluetooth accessibility to "Read ONLY." You can override outputs, but you cannot make configuration changes anymore. In collective settings, you must connect to the Collective WiFi master to override outputs.
- [FIXED] - Issue wherein a collective of multiple devices, you could not specify the exact device where the 0-10V button box was connected to in the options page under "Mode Control Input."
- [FIXED] - Unable to turn ON Kalk reactor stirrer manually. Both output tiles would turn on the reactor pump.
- [FIXED] - Converted Notification Interval to dropdown and no longer allows customers to set time to 0.
- [FIXED] - Fixed issue when trying to restore from cloud backup, and the app would not uncompress the file before reading it.
- [FIXED] - Issue where if there were only one input or output, a gray box would display instead of in the status screen
- On collectives, you can no longer remove the last device. Instead, we require you to remove the collective to ensure customers do not end up with empty collectives.
- [FIXED] - After creating a collective, a second reboot was required to access the status screen.
- Customers cannot create empty collectives anymore.
- Customers cannot create a collective with a WaveEngine.
- [FIXED] - On large collectives, it would take several attempts to upload a configuration change to all devices.
- [FIXED] - Issue with TDS meter showing red even though the sensor was connected to the unit.
- [FIXED] - Issue when upgrading WE firmware on large collectives
- Added RODI preset
- Implemented new code to make the collective more reliable during firmware updates
- [FIXED] - Many issues with IceCap Controller
- Added constant refresh to IceCap Controller
- [FIXED] - Issue in the collective, where having ETM enabled would always prompt an update even if there were no changes
- Optimized uploads in collective and WaveEngine to make them faster on larger collectives
- [FIXED] - Multiple small bugs
- [FIXED] - Correct video is shown when pairing a WiFi Feeder
- [FIXED] - Size rendering is now fixed as we are using a new rendering engine that ensures that everything looks the same on all platforms (iOS, Android, Windows, Mac)
- Added "Pages" with cross-platform support
- Added ability to reorder tiles, graphs, and text with cross-platform support
- Renamed HYDROS devices to reflect the new official names instead of internal names
- Bluetooth access is now Read-Only. One can still override outputs but can no longer make configuration changes in Bluetooth mode.
- Extended the ORP range to include negative numbers and accommodate nitrate reactors.
